1st March February 2012
Latest post 02-01-2011 4:22 PM by Evan. 22 replies.
05-01-2007 5:53 PM
Xseries
- Joined on 04-16-2007
- Hampshire
- Posts 433
Useful Hints and Tips for Beolink 1000 and Beo 4
Does anyone have a list of useful extra codes, hints and tips to make MCL equipment work using the Beolink and Beo 4 terminals? I am looking to connect a pair of MCL2AV with MCL2Ps in the same room to drive surround sound and would like to know if I can control them separately with a remote and the right codes. Any other unearthed secret operations would be most welcome as well!
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Useful Hints and Tips for Beolink 1000 and Beo 4
I think we need a list at some time and when we have compiled this we will put it under FAQ. Good idea.
Coolskin
- Holland
- Posts 505
There was a list on the previous Beoworld.
A feature I like is keep pressing the BEO4 LIST button and the LCD will scroll the info. When you release, and press LIST button briefly time and time again, the scrolling is in the opposit direction... Very usefull if your LIST list is stacked with lots of items.
Tom
- Luxembourg
- Posts 3,175
on the old forum, there was a "tipps and tricks" site, which I can not find back any more here on the new beoworld. I asked about it, but did get no answer. I think that such a page should be available on this site too
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
tom: on the old forum, there was a "tipps and tricks" site, which I can not find back any more here on the new beoworld. I asked about it, but did get no answer. I think that such a page should be available on this site too
Hi Tom we are still "hopefull" of getting back into the old site so feel it's better to wait rather than try and reconstruct work already done. I agree though it was a very useful page which I could do with myself!
Erik-nl
- Joined on 06-27-2007
- Posts 127
In relation to this is Beo4 <MENU> <0> <0> <GO> the same as Beolink 1000 <MENU> <0> <0> <PLAY>
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Beolink 1000
- SHIFT
then RADIO opens the AUX port
- SHIFT
then SAT gives you CDV/DVD access and control
- SHIFT then
A.TAPE controls A.TAPE2
- PICTURE and << >>
changes position of the motorised stand
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Ignace: - SHIFT then SAT gives you CDV/DVD access and control
I use [SHIFT] [CD] Ignace: - PICTURE and << >> changes position of the motorised stand
I use [PICTURE] [<] or [>]
Friedmett
- Joined on 04-28-2007
- Herning, Denmark
- Posts 840
Something I came across with my Beolink 1000 mk3. The clock works normally with the play button, push once for shorth time and push twice for it to stay in the upper right corner. This is clear in the manual. However when using video use it's: sound or picture+ play once or twice depending if it should be permant in the upper right corner. I have my JVC dvd player on AV2 and use Shift + Sat to engage it. It depends on what you have selected in the tv menu setup. The sound/picture + play gives the same clock options as when video is selected. The manual does not say anything about this at all.
Ignace
- Moderator - NL
- Posts 2,749
Daniel: Ignace: - SHIFT then SAT gives you CDV/DVD access and control
Yes, it may be different, depends on which Beolink 1000 and which B&O product you want to control with it. On my MX7000 + Beolink 1000 Mk3 : SHIFT + SAT = DVD (actually, it displays CDV)
Daniel
- Svinarp, Sweden
- Posts 1,284
I'm posting this with some frightening and hope it will only result in 1 post and not 12. I guess I have a Mk2 [SHIFT] [CD] display CDV on LX [AV] [SHIFT] [CD] displays CDV on BS 9000 Mk2 By the way what does Mk stand for?
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Mk stands for MARK which means version number. So, a Mark I is the first version
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Daniel: - PICTURE and << >> changes position of the motorised stand
Neither of these works for me I have a later MX6000 (type 7810, "IT" model, which came with a Beo4) and I haven't yet found a way to control the stand with a Beolink 1000 Mk.2. Any other possibilites? The stand works just fine with Beo4.
Ignace
- Moderator - NL
- Posts 2,749
Correct, i had the same with a MX7000 IT. With Beolink 1000, i could only control the stand from within the on screen menu.
Keith Saunders
- Posts 3,810
I think Peter is correct, we need a FAQ for these two remotes as I see a lot of these type of questions. Please continue posting both your hints and tips and we will make an FAQ out of them.
Xseries
- Hampshire
- Posts 433
Re: Useful Hints and Tips for Beolink 1000 and Beo 4 - now extend to include 7000
I can't believe how quickly 18 months has passed since I started this thread. I would like to find out also if anyone has found anything interesting on a Beolink 7000. Are there any diverse functions available on one of those - for Avants, DVDs, later Beovisions etc etc.
Christian
- Copenhagen, Denmark
- Posts 626
Is there a way to turn on/off random on a BS9000 with a BL1000?
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
PhilLondon
- London
- Posts 2,545
I think it is SHIFT + a number, I do not remember which one. p.
Christian
- Posts 626
Great! SHIFT 0: Turns EDIT on and off. SHIFT 1: Turns RANDOM on and off. SHIFT 4: Allows me to SELECT cds. Many thanks.
nmartin771
- Joined on 02-18-2008
- Novi Sad, Serbia
- Posts 3,103
Some Beo4 useful tips ???
when your Black Label begin to taste like juice just take shot or two of Absinthe and
after that quench with some vodka, if you still feel juice like take beer
with grappa !
Ferdinand
- Joined on 05-04-2008
- Malmö, Sweden
- Posts 159
Hi All,
lately I have been more 'posting-active' but (unfortunately) only asking for information.
Hopefully my comment in this thread can be of some value: on B&O remotes the '0' (zero) makes you switch between two channels on the television. Let's say you watch a movie on channel 11 and sports on channel 24 you can easily switch/swop by pressing '0'
BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Ferdinand:
Hi All,
Yes, the zero key function carries over to other devices also. Such as the tuner in my Beomaster. It will recall the last selected radio station exactly the same way the TV recalls channels.
Page 1 of 1 (23 items)
