Latest post 03-07-2008 11:25 AM by davespain. 2 replies.
Page 1 of 1 (3 items)
  • 02-26-2008 9:53 AM
    Interlink cables for Beocenter 5000
    I have just been given a beocenter 5000 but it is missing all the cables. I can see that they are roughly the same as standard DIN fittings but I have no idea if a standard/off the shelf cable is available or if I need to buy something special or make it up. I am completely comfortable with soldering fittings similar to this but i have now idea of what the conections should be or wether I can get the plugs easily.Can anyone help? I would love to get the system working.Thanks Dave
  • 02-26-2008 10:57 AM In reply to
    Re: Interlink cables for Beocenter 5000
    Congratulations on your freebie. You will be pleasantly surprised how good it sounds when you get it going!
    The speaker cables are 2-pin DIN male at one end female at the other (assuing you have a set of B&O speakers), you can use the 5 pin DIN Tape in connector at the front to connect a CD Player, you can buy suitable RCA to DIN converter leads on eBay or from  Maplin relatively inexpensively, so there is no real need to make your own leads.
    Simon
  • 03-07-2008 11:25 AM In reply to
    Thanks Simon. It is what I expected but the last thing I wanted to do was muck up the connections and blow it all up. Too sad to think about.Dave
