Hi All
I have my MX3500 connected to my MX7000 via the 7-pin Beolink.
MX7000 is master and MX3500 slave (link-tv)..
Everything works exactely how I expect. If I press a source, that is not locally configured on the MX3500, it will try to link it throgh the Mx7000.
If I change the MX3500 to Master mode, I can still access linked sources by pressing LINK before the source.
Well. Here comes my problem:
If I wat to change the MX7000 to Slave, and the MX3500 to Master things don't work as I expect.
It seems like, I can't change the MX7000 to Slave mode, even that the LED flashes. when I try to change the v.option.
The MX7000 doesn't try to link a source that is not locally configured. Not even if I press LINK
Does the MX7000 need a videolink kit, or something like that??
I'm a bit confused
