Latest post 02-21-2008 8:15 AM by wessel. 0 replies.
Page 1 of 1 (1 items)
  • 02-21-2008 8:15 AM
    • wessel
    • Not Ranked
    • Joined on 08-22-2007
    • Posts 3
    MX7000 linked with MX3500 change master-slave direction
    Hi All
    I have my MX3500 connected to my MX7000 via the 7-pin Beolink.
    MX7000 is master and MX3500 slave (link-tv)..
    Everything works exactely how I expect. If I press a source, that is not locally configured on the MX3500, it will try to link it throgh the Mx7000.
    If I change the MX3500 to Master mode, I can still access linked sources by pressing LINK before the source.
    Well. Here comes my problem:
    If I wat to change the MX7000 to Slave, and the MX3500 to Master things don't work as I expect.
    It seems like, I can't change the MX7000 to Slave mode, even that the LED flashes. when I try to change the v.option.
    The MX7000 doesn't try to link a source that is not locally configured. Not even if I press LINK
    Does the MX7000 need a videolink kit, or something like that??
    I'm a bit confused
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
