Replace capacitors, especially all those 22uF ones, and check those dreadful rivets as it is mentioned somewhere else on this forum.
It makes good sense to remove the old solder from the rivets and loop a cooper wire through instead, soldered to the PCB tracks on both sides. Takes time but is worth it.
