Latest post 02-08-2008 5:59 AM by Eugenio Colazzo. 2 replies.
Page 1 of 1 (3 items)
  • 02-06-2008 10:56 PM
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    CDX question mark on display?
    Hey guys,
    I recently acquired a nice looking cdx.  There was an issue with the door not closing properly.  When you'd hit play the door would try to close further.  After adjusting the door mechanism inside I've fixed that.  Now however when I touch play I just get the question mark on the display.  In the user manual it gives some minor reasons regarding playlist programming for the question mark, but this isn't playlist related.  Does anyone know what it indicates or what I could check?
    Thanks,
    Austin
    -Austin (resident audiophile skeptic)
  • 02-07-2008 3:19 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: CDX question mark on display?
    Replace capacitors, especially all those 22uF ones, and check those dreadful rivets as it is mentioned somewhere else on this forum.
    It makes good sense to remove the old solder from the rivets and loop a cooper wire through instead, soldered to the PCB tracks on both sides. Takes time but is worth it.
  • 02-08-2008 5:59 AM In reply to
    camshaft:
    Hey guys,
    Thanks,
    Austin
    Hello
    The question mark is used to indicate an error, nothing else.
    Eugenio Colazzo
