Latest post 01-28-2008 4:20 PM by auric. 1 replies.
Page 1 of 1 (2 items)
  • 01-28-2008 5:23 AM
    Packing a 4002?
    I think I've found myself a Beogram 4002 from abroad. In case the seller hasn't done this before, is there any specific advice on how to pack this thing so I won't receive a box full of shreds?
    -mika
    -mika
  • 01-28-2008 4:20 PM In reply to
    Re: Packing a 4002?
    Assuming the seller does not have the original packaging, extra care will be necessary to package  your turntable.
     - Make sure that you instruct the seller to lock down the transport (3 screws on the bottom).
    - Remove aluminum platter (+ sub platter), wrap separately with bubble wrap and card board to avoid, dings, scratches, nics.
    - Tape down all aluminum surfaces especially side panel under tone arm.
    - Tape down wood trim to chasis.
    - Remove Stylus and package separately with guard.
    - Put a foam block between and underneat tone arm and tape down.
    - Coil power cord and wrap the end of the plug so that the prongs are not exposed. (If left loose it could move around and scratch the deck up)
    - Tape down dust cover.
    - Double box the item with lots of pop corn and bubble wrap.
    Derek
