Assuming the seller does not have the original packaging, extra care will be necessary to package your turntable.
- Make sure that you instruct the seller to lock down the transport (3 screws on the bottom).
- Remove aluminum platter (+ sub platter), wrap separately with bubble wrap and card board to avoid, dings, scratches, nics.
- Tape down all aluminum surfaces especially side panel under tone arm.
- Tape down wood trim to chasis.
- Remove Stylus and package separately with guard.
- Put a foam block between and underneat tone arm and tape down.
- Coil power cord and wrap the end of the plug so that the prongs are not exposed. (If left loose it could move around and scratch the deck up)
- Tape down dust cover.
- Double box the item with lots of pop corn and bubble wrap.
Derek
