I would like to connect an HD satellite receiver to my Beovision 6-22 using the DVI port.
Anybody knows how to select the device for the "devices list" so that I can control the receiver using my Beo4 remote control?
Under Connections, I see: ( I press Menu,Options and then CONNECTIONS)
V.TAPE ...... (V.TAPE,V.TAPE + DECODER,DECODER,V.AUX,NONE)
AV ............. (STB, NONE, DECODER, EXPANDER, EXPANDER+DEC, V.AUX, DVD)
Usually, the DVI port is accessible using "PC" button on the Beo 4. I do not see "PC" under "Connections".
How to assign the IR codes in this case?
Thanks.
