Latest post 01-28-2008 7:00 AM by Sebastien. 2 replies.
Page 1 of 1 (3 items)
  • 01-27-2008 2:38 PM
    Beovision 6-22
    I would like to connect an HD satellite receiver to my Beovision 6-22 using the DVI port.
    Anybody knows how to select the device for the "devices list" so that I can control the receiver using my Beo4 remote control?
    Under Connections, I see: ( I press Menu,Options and then CONNECTIONS)
    V.TAPE ...... (V.TAPE,V.TAPE + DECODER,DECODER,V.AUX,NONE)
    AV  ............. (STB, NONE, DECODER, EXPANDER, EXPANDER+DEC, V.AUX, DVD)
    Usually, the DVI port is accessible using "PC" button on the Beo 4. I do not see "PC" under "Connections".
    How to assign the IR codes in this case?
    Thanks.
  • 01-27-2008 4:59 PM In reply to
    Re: Beovision 6-22
    Hi
    The BV6-22 isn't HD-ready so thats not possible to assign the DVI-port to DTV and STB-controller. You can do a HD-ready upgrade but I don't think thats worth the cost on that picture size. Use a RGB-Scart and you get a picture that's good enough.
    /Ola
  • 01-28-2008 7:00 AM In reply to
    Re: Beovision 6-22
    How to do the same with the Beocenter 6-23?
    ( How to  assign the IR port with the DVI input)
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
