Hi everyone, has anyone seen a problem like the following before?
I recently bought the BeoPort kit and installed it successfully connected to / running on my iMac (running OSX Leopard) on Windows XP running on a Parallels Virtual Machine (I also have it working directly with iTunes on 'native' OSX using Anders Odlund's BM-Link software and it works fine).
My setup doesn't have an IR eye or any active speakers connected to the BeoPort box because my iMac is in a room that is already served by an IR eye and a set of passive speakers linked back to my main system (a BeoSound 9000) via a Beolink Passive box.
After the initial install of the software in the XP Virtual Machine, everything worked fine and I was able to see and use all my sources ie CD, RADIO etc as well as the 'PC' sources (N.RADIO, N.MUSIC, PC-CD etc), all via the PC Control Bar. However, after restarting the system, I seem to have lost all the 'non-PC' sources (CD, RADIO etc). Somehow the system is not detecting that they are there. Everything else is working fine. I was wondering if I had a faulty connection, but as everything works in native OSX mode (eg the track names etc are communicated back to the 9000's display), I don't think it can be that.
Any ideas would be much appreciated.
Michael
