Latest post 01-20-2008 8:25 AM by Russ. 2 replies.
Page 1 of 1 (3 items)
  • 01-19-2008 6:36 PM
    • Goldfrog88
    • Top 500 Contributor
    • Joined on 06-07-2007
    • Melbourne, Australia
    • Posts 83
    • Gold Member
    Hmm [^o)] Which is the best panel to buy for a BS3?
    Guys, I'm looking to upgrade the Sharp AQUOS I have hanging off a BS3, because it isn't HDCP-compliant (only sports a DVI connection). I'd love a BV9, but they are the price of a new family car.
    I'd like to buy a 50 or 52-inch panel, preferably with high-def digital built-in tuner.
    Should I go plasma or LCD? Should I look at 100Hz panels?
    I'm thinking of Sony Bravia, Panasonic or Sharp AQUOS D64 types.
    Any thoughts greatly appreciated.
  • 01-20-2008 7:22 AM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Re: Which is the best panel to buy for a BS3?
    Goldfrog88:
    Firstly, just because your Sharp only has DVI does not mean that it wont support HDCP- The connetion on the BS3 to BV4 is via DVI!
    Clearly though there is a compatablity issue with your sharp.
    LCD panels just wont do it with the BS3 im afraid- you can get some that will work but not very well and if you watch a lot of SD material the results will not be that good. If you want to stick with LCD Sharp is the best of the makes you mentioned.
    For plasma you need the panasonic P9/P10 commercial panels- these have no tuner.
  • 01-20-2008 8:25 AM In reply to
    • Russ
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    You will also find that the Panasonic monitors have a curious RS-232 socket which bears a strong resemblance to the one on the BeoSystem 3.Wink
    Monitors, not TV's.
    The BS-3 has the Digital tuner in it already (at least on this side of the pond.)
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
