Latest post 03-31-2008 5:01 PM by PalM. 7 replies.
Page 1 of 1 (8 items)
  • 01-14-2008 6:20 PM
    • Flyer
    • Not Ranked
    • Joined on 12-08-2007
    • Posts 3
    • Silver Member
    Sad [:(] Beolab 8000 power problem
    I have a pair of BL8000s. A couple of weeks ago, I was aware that the LED on one wasn't lit. Checked the fuse in the plug, swapped the speaker onto the working power connector and it still wouldn't power up. I dismantled the 8000 and checked the internal fuses with a meter; they hadn't blown.
    Any ideas what else could be wrong?
    Assuming it needs a B&O technician, can anyone recommend someone in the Warrington, Cheshire area?
    Thanks,
    Andrew
    Filed under:
  • 01-15-2008 3:32 AM In reply to
    Re: Beolab 8000 power problem
    Andrew,
    When you say "I was aware that the LED on one wasn't lit" I am assuming you also mean the speaker itself was not working.
    Below is the transformer circuit so you can check with a meter if you are getting output. If you are then the problem will either be:-
    • The protection circuit which cuts the low voltage power circuit if there is a problem.
    • The power off/on circuit from pin 4 of the powerlink not working
    • Or the low voltage power supply itself.
    If you have power output on teh secondary of the transformer below, then its one of the above, so you would need to take it to a dealer for repair. If you are in Warrington, why not take it to Kings Street in Manchester.
    Beolab 8000
    Regards Keith....
  • 01-15-2008 5:01 AM In reply to
    Hi Andrew,
    Apologies, I did mean to follow up on your pm, I have not been back on mb forum since my last message to you.
    You will find an answer on here though and welcome aboard.
    m
  • 01-21-2008 3:27 PM In reply to
    • Flyer
    • Not Ranked
    • Posts 3
    • Silver Member
    Thanks Keith. Yes, the speaker itself wasn't working.
     I've gone past the stage where I'm comfortable working on it, so it looks like it's off to a dealer. How long is a piece of string question: would you have any idea of repair costs (clearly dependant on what's failed I know, but do you know a dealer's labour rate?)
    I see that Ian Kinsella is at Kings Street; I've had several conversations with him at Warrington, although I used to deal with Russ. I'll give them a call and see what's involved in getting it to them.
    mobe, cheers for that, just hope I can get it repaired reasonably. The Merc's cost a fortune this year! :)
  • 01-21-2008 3:59 PM In reply to
    The typical dealer service rate in my area is around £60 per hour.
    Regards Graham
  • 01-21-2008 4:01 PM In reply to
    Flyer:
    Hello Flyer,
    Ian Kinsella is indeed here at King Street - and regarding your repair, we are also pleased to have the services of another ex Plumbs employee - Ray from HPS.  He was actually sent over to Denmark ( in about 2000 ) for 25 years service as a B&O bench engineer - so bring your lab 8000 in - "we can repair it, we have the technology" !!
    Best Regards,
    David
    Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
  • 01-21-2008 7:46 PM In reply to
    • Flyer
    • Not Ranked
    • Posts 3
    • Silver Member
    Hello David,
    Thanks for that. Do you have any late-nights? I work in Oldham, so could drop it off on the way home one night if you do. Can you park nearby (long enough to drop off)? Not sure I want to come in as I don't want to be tempted!
    Cheers
    Andrew
  • 03-31-2008 5:01 PM In reply to
    • PalM
    • Not Ranked
    • Joined on 03-31-2008
    • Posts 1
     I have the same problem but do not know how to dismantle the speaker (and I need to do that as I want to repair the internal power cable which I can see is broken). Can you or anyone please advise how to dismantle the speaker? I could not find that in the service manual.
     Many thanks
    Paul
