Yes, but it does not support fast scrolling or fast forward or fast rewind. Updating you IR list is not as simple as just uploading a new full list, you have to create your own desired list from the choice of available boxes. This is why I said that you are best to list all your current boxes that are used then add the other specific boxes you require. You can find out what is on the list by visiting your dealer, dont bother calling them as it is best to see for yourself if they allow. As I said, if they have the software and cables to perform the update, this will only take them half an hour or so, from creating your specific list to uploading it to the BeoSystem 3 and BeoCenter 6 26. The cost of updating your equipment will be down to the dealer, it is not, if i am correct a free service.
You may wish to update your BS3 software while your at it, I think it has now gone to 4.1. This will have fixes for issues that have been occuring recently. This all depends on which software you currently have on the BS3, to find out press MENU to get into the BS3 menu, then press 0 0 Go, then highlight Monitor and press Go, you will see the top line looks something like: 06 IC3 AP SW03.10a (this will be the software version you currently have on the BS3).
Vinnie.
