1st March February 2012
Latest post 01-31-2009 6:05 AM by JC. 28 replies.
04-25-2007 5:31 PM
TheBogusMan
- Joined on 04-16-2007
- Posts 15
Underrated B&O-features you really like...
I was wondering whether there are any "unimpressive" features of your B&O products that you really like? We all know the products have great design, terrific link capabilities, are very user-friendly and so on, but are there some "small" features you don't want to miss anymore? For example I really like the auto-standby function of my BeoSystem. This allows me to leave the house without having to think that I might have forgotten to turn off my stereo. And - that's the real great thing - I can listen to music to fall asleep (even LPs) and I know that the whole system will shut down automaticly!
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
Re: Underrated B&O-features you really like...
Well it's probably a major feature and sometimes shooting B&O in the foot but I like the fact that their gear, even the modern stuff is meant to be repaired. A feature lost in the if it's broke chuck it out and go to Dixons society we live in.
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Personally, i very much like the compatibility of "older" and new(er) products
and the option of integrating separate components to the system.
beo-ap
- Posts 231
I like and regularly use the Picture Mute function on my Avant. This really only makes sense wiith a TV that also has fantastic sound. Still, I would use this feature useful even in my Samsung LCD. I don't know of any other brand with this feature. Do you?
RicardoBathUK
- Joined on 04-19-2007
- Posts 27
peria:I like and regularly use the Picture Mute function on my Avant. This really only makes sense wiith a TV that also has fantastic sound. Still, I would use this feature useful even in my Samsung LCD. I don't know of any other brand with this feature. Do you?
I agree this feature on my BV3 32" is great as I use a Panasonic DVD recorder and as I haven't managed to purchase my B&O 9000 CD payer yet, I listen to CD's through eh DVD player using my B&O TV with the picture turned off! Also useful for listening to DAB radio through my Freeview box! I also like the feature that if I go away for the weekend, but still want to record things whilst away I can turn the TV off and know that of someone comes in to steal it , the PIN code facility is on!
History - it's just one thing after another!
Tom
- Luxembourg
- Posts 3,175
well, it is not a feature, but i love the sound my BL8000 produce when they switch on/of (that click). sounds like music to my ears
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
djjkroon
- Joined on 04-18-2007
- Uddel, the Netherlands
- Posts 113
One of the most underrated options is the two way communication of the older models. Why not (again) two way remote controls and displays in the linked hardware such as(active) speakers. Musical regards, Hans Kroon
Muzies,
Hans Kroon
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
The little rubber feet on the base of the Beolink 1000. Very simple and elegant idea which protects your remote and whatever you are placing it on and has been lost on the Beo4. It's these tiny attentions to detail that I really like. Chris.
gk31ax
- Posts 220
I love the fact that holding down the standby button turns everything off....
seheiste
- Joined on 04-21-2007
- Stockholm
- Posts 27
Hi, maybe a stupid question, how do you mute the picture on BV3 32? I could do it on my LX5500 but have not figured out how to do it with BV3. Best regards, Heinz By the way, my most unwanted feature is my Set top box controller switching off my cable box after watching normal TV for a while.
j0hnbarker
- LS28/GB
- Posts 2,002
I like the damped action on the volume wheel on the Beomaster 8000, compared with the undamped frequency wheel. Very necessary and very well thought through! I also like the way you can get the time by pressing 'Status' on an MCP5000 without turning on the Beosystem. Very useful if you want to use the MCP as a bedside clock :)
catalinex
- Joined on 04-26-2007
- Bucharest
- Posts 4
Hi, If you are using a beo4 remote, press between the up and down volume button. Best regards, C
... from Spark to Icon
beobeo
- Spain
- Posts 953
I really like it on the BS9000, when the car moves from one position to another, it will do it slower if the glass door is open. And if you approach your hand as if you want to change a CD, the car will stop moving to avoid hitting you! Pure magic. More on BS9000. Invite your friends. Put 6 cd's of your favorite music in it. Enable random function, dim lights and look at the eyes of your friends. Guaranteed in less than 20 seconds they will make an exclamation comment. It's just so accurate and fast when it works in random. Make sure you clean the way in which the car moves regularly, otherwise gets slower.
Tom
- Luxembourg
- Posts 3,175
seheiste: maybe a stupid question, how do you mute the picture on BV3 32? I could do it on my LX5500 but have not figured out how to do it with BV3....
i don't know if it p-mute is available on a BV3, but on the BV7, you have to add "p-mute" to the fonctions of your Beo4, and then just chose it with the list button...
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
catalinex: Hi, If you are using a beo4 remote, press between the up and down volume button. Best regards, C
Hi Catalin. That just mutes the sound, he wants to mute the picture. Andy T.
Kevin
- Moderator
- Posts 1,256
Is the p-mute function in the list only available on later Beo4's mine doesn't seem to have that?
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
gk31ax:I love the fact that holding down the standby button turns everything off....
That is what I was going to put. Also the way the light stays on. Very clever. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Kevin
- Moderator
- Posts 1,256
Craig: gk31ax:I love the fact that holding down the standby button turns everything off....
Yes makes you wonder if that was theory or practical experience " who turned that light off!...... crash there goes next months wages!"
Jandyt
- Posts 13,004
Serene shares 'phonebook with Beocom 6000. Very handy for Andy. Andy T.
Mike
- Germany
- Posts 20
I like the sound slowly fading out when I switch off my BV6.
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
I love the leather pouch for my A8s and the filters on the 4 lights of my BS3200 are just perfect.
RicardoBathUK
- Posts 27
seheiste: Hi, maybe a stupid question, how do you mute the picture on BV3 32? I could do it on my LX5500 but have not figured out how to do it with BV3. Best regards, Heinz By the way, my most unwanted feature is my Set top box controller switching off my cable box after watching normal TV for a while.
Hi! To mute the picture on the BV3 32" (or turning the screen off so all you hear is the sound!) On the BEO4 remote, press "List" until "AV" appears and then pus the source button you are listening to so for example if like me you use "DTV" to listen tot he radio through Freeview, press "LIST", "AV" then "DTV" and the picture will turn off, the sound mute for a second,m then the sound comes back on again. You can still change the volume as normal and even mute the volume, but the stand wont operate. To turn the picture back on, press one of the source buttons again. Such a simple idea, but I did have to ask my dealer a few weeks later, after he showed me when it was installed as I couldn't remember it! I also love the fact you can sort your favorite list functions on the remote so if you use a particular function regularly you can have that appear first when you press LIST instead of scrolling all through them, as we ll as removing options you wont use (Not something I have done, as i didn't want to get rid of them!) One thing I have found is if you have a good dealer (Like we do in Bath!) they are more than happy to talk you through things over the phone, mine called me back when he wasn't sure if the P-MUTE option was installed on the BV3! I hope that helps! Cheers Richard
seheiste
- Stockholm
- Posts 27
RicardoBathUK: seheiste: Hi, maybe a stupid question, how do you mute the picture on BV3 32? I could do it on my LX5500 but have not figured out how to do it with BV3. Best regards, Heinz By the way, my most unwanted feature is my Set top box controller switching off my cable box after watching normal TV for a while.
Hi Richard! Thank you very much for the information! I'll try it out but it may not work in DVD mode. I want to view the DVD, (I use DVD 1), with a projector on the wall behind/above my TV. Therefore I want to keep the surround sound but not the picture. It's possible to reduce the brightens and contras to zero which kind of mutes the picture but I don't think it's very user friendly.
mfirst
- Posts 155
true - that is if you dont mind spending a forture to get anything fixed.
Christian
- Copenhagen, Denmark
- Posts 626
Mike: I like the sound slowly fading out when I switch off my BV6.
This goes for the light also. Dimming up/down not switching on/off, much more plesant for the eye.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
