1st March February 2012
Latest post 05-07-2008 9:06 AM by majand. 19 replies.
01-04-2008 8:25 AM
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Just got a second hand 1996 ouverture from ebay (the ad quoted technically and optically perfect). It's really nice, but oh so different to a Beosound 4!
and wanted to check about the doors, and how there is a gap between them when they are closed, mine has a 2 mm gap when they close but has practically no gap if i physically push them shut from the sides, is this normal or does my machine need a service? They are also not very quiet in movement, they sound dry and louder than the beosound 4, otherwise it is perfect in operation. Also, one of the doors is different and looks older it has bubbles between the clips and the glass, does a new door cost alot?
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
I had the same issue with the doors of my BS2300. In my case the door mechanism needed replacement. I also had the CD mechanism replaced at the same time. The repairs cost me about 480 euros in total (about 800 australian dollars). I don´t know how much the door mechanism would cost seperately.
Dave
- Posts 2,328
It's a very minor gap difference, surely it can just be tightened and lubricated... i would never spend that much to fix it, i paid 900 aus for it!
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
The doors are not supposed to touch and 2mm gap is normal/small. I would not recommend pushing the doors together as above. The sliding tracks do wear out and on one of this age they could probably not be at their best. It will never be as quiet as your BS4 as there are more moving parts to consider. Not a difficult job to replace the tracks and instructions are provided in with the kit. They would run quieter if replaced. The new tracks include invisible rubber buffers in the centre of the doors to prevent them closing too far so there is always a gap!!!! The glass doors are replaced individually and the glue holding the metal bits on does deteriorate with age. Cost is about 40gbp per door. You could replace doors, track, black plastic panels, cd mech. But how far do you go???
ChrDH
- Denmark
- Posts 493
If it is any comfort my 1996 ouverture also has about a 2-3mm gap... br Chr
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
Goldfrog88
- Joined on 06-07-2007
- Melbourne, Australia
- Posts 83
Dave, it is possible to remove and replace the doors, putting them back a little closer if you must. The other respondents say 2mm is OK; my Ouverture is about 1mm, so 2mm is fair. However, if you want to take the doors off, switch off the whole system unplug everything and place the Ouverture with its doors up on a table. Grab just one of the glass doors and pull it upwards reasonably sharply, keeping it as horizontal as possible. It will appear to break out of the holder, (but can be put back with a little push). Take off the other door. Now push the doors back, one by one, trying to keep the central distance close. Et voila! If you feel uncomfortable with the procedure, your local centre should be able to show you (at least the service will ... no more said). Hope you are enjoying the Ouverture. I've just ordered from China an MP3 player with SD card slot built in a cassette case that should enable me to play MP3s using the Ouverture's cassette bay. I saw it in a recent UK Stuff magazine. You might follow that up if it's of interest.
Dave
- Posts 2,328
Thank you all for the correspondence i will consider all of the above, unfortunately i'm plagued with extreme fussiness, so the gap really gets to me. Goldfrog88, i tried what you said but i don't see how this procedure could work. Seems impossible to me, The doors not closing is internal and the only way to fix it is to tighten those clamps inside. I'm going to have to put up with it. The sd tape deck sounds like a good idea, but how would it read an sd without batteries
Goldfrog88
- Posts 83
Dave, it's some years since I did this, but I'm sure the tracks stay on the Ouverture and the clips (that clip into the tracks) are glued to the glass. Cheers!
Dave
- Posts 2,328
Ah i thought so, well i should just stick to using the BS2 through AUX (as soon as i get the charger fixed).
joeyboygolf
- Posts 3,252
Kokane81: there is a rubber stop in the middle which stops you from making it possible to shut the doors together fully so doing what i say won't damage anything and got told to do this by B&O. What they said is you get slack in the metal cable which cause the doors not to shut properly and those clamps are there to make slight adjustments.
There is no rubber stop in the centre of older models! Adjusting older ones too tight may result in the doors contacting in the centre and causing damage. There is supposed to be a gap in the middle!!!! Specification for the gap on sliders with rubber buffers is 1.2mm +/- 0.6mm
joeyboygolf
- Posts 3,252
Dave: Thank you all for the correspondence i will consider all of the above, unfortunately i'm plagued with extreme fussiness, so the gap really gets to me. Goldfrog88, i tried what you said but i don't see how this procedure could work. Seems impossible to me, The doors not closing is internal and the only way to fix it is to tighten those clamps inside. I'm going to have to put up with it. The sd tape deck sounds like a good idea, but how would it read an sd without batteries
The individual sliders are clamped onto the wire and the only way to adjust is to loosen the clamps. This involves removing the back of the ouverture, then removing the bottom electronic pack. This enables access to the clamps. Only adjust one door at a time or you could end up with a mess!!
erikssmt
- Joined on 12-29-2007
- Posts 4
I´ve got a pretty decent gap too, 2-3 mm. Is it normal? ![]()
majand
- Joined on 02-26-2008
- Helsinki
- Posts 72
Hi, I bought an second hand Ouverture and it arrived with the doors removed. The sliders seem to be on the unit and in the glasses there is just a residue of a glue of somekind. My question is: What kind of a glue should I use to fix the doors to the unit? Any recommendations?
Page 1 of 1 (20 items)
