1st March February 2012
Latest post 01-01-2008 4:34 PM by Craig. 20 replies.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: AV system , need help with link options
Hi Patrick firstly welcome to Beoworld. This lot should be quite simple to set up. From what you say you have it all set up correctly. As in the BS9000, the Avant and your Beoport should all be connected to each other via Masterlink. Then the speakers should be connected to your Avant via Powerlink. You should set your equipment to the following options. BS9000 - Option 0 Avant - Option 2 Beoport - Option 6 To set the options press the Red Spot (off) button and the List button at the same time. Then using the up/down button select Option. Press GO then select A.Opt followed by 0 for the BS9000. You will know if has worked as the stand-by light will flash a couple of times. Then do the same for the Avant, but select V.Opt then 2. For the Beoport. Select Setup then Config. Go in to Advanced and there you can change the option settings. Hope this helps. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
patrickpeeten
- Joined on 12-31-2007
- Posts 11
thank for the help craig , i'll definitly try this out !
I made a scheme showing my current setup. it might clear up the situation a bit
 Im hoping to set up my system in the following way: BS9000 serves as CD/Radio source/Aux.Input Avant serves as TV/VCR/DVD Beoport serves as Net music/net Radio, etc BL2500 serves as output in room 3
I hope to get all these audio sources through the Avant into the room1 speakers and the BL2500
for the programming part the Option settings would be enough , craig did a wonderfull job explaining the Beo4 command above Is theire any particular way or order in which it has to be done? I read somewhere on this forum that you need to disconnect all ML and then program them. Do you need to program the BS9000 for example so that when you press CD on your Beo4 it automaticly looks for CD input in your BS9000 even when 'aiming' the Beo4 at your TV ?
This is probably a common B&O setup , but i find that the manuals cant quite cope with user/community experience. I'm hoping to get answers to these questions , testing it on my setup and ultimatly creating a sort of guide/tutorial on how to connect/program it all, so it can help other people in similar situations. And maybe avoid having this kind of people needing to call technicians for problems that are other wise easily solved with a clear scheme or guidelines. This is what i think is the great advantage and strength of a forum/community.
Peter
- Joined on 02-12-2007
- Posts 9,572
You will need a Beolink Active for the room with the Beolab 2500s in. What you need is the Product Configuration Guide which is a B&O program that allows you to design your own system and then gives you detailed instructions on how to set it up and all the options needed. It is in the downloads section for silver and gold members here. Well worth getting as it allows you to design complicated systems and then print out the instructions.
Craig
- Posts 4,855
Patrick in your diagram you have room 3 as containing BL2500. These are a pair of speakers which as Peter has said would require a Beolink Active to work. Although I notice that you only show one. Do you mean a BL2000 or BL35000 which are stand alone units. See the links below. BL2000 BL3500 Craig
patrickpeeten
- Posts 11
Yes its a BL2000 not a 2500 I'll check out the program and get the silver memb ship. Sounds like an interesting tool :)
Craig
- Posts 4,855
Hi Patrick, you need to set your BL2000 to Option 6. This is done just as I described but I think you need to use L.Opt then 6. Everything should then work as you want. Craig
patrickpeeten
- Posts 11
Ok , ill try those settings Do you have
patrickpeeten
- Posts 11
Ok , ill try those settings Do you have to set which one is the default CD or radio source or is it done automaticly?
Craig
- Posts 4,855
Now it will do it all automatically. Just one thing to add, make sure the units are in stand by when you set the options. Craig
patrickpeeten
- Posts 11
Im ready to give it a try now , ill let you know in a few minutes
Craig
- Posts 4,855
Hope it works out. Craig
patrickpeeten
- Posts 11
I've set the options , but the TV doesent respond to CD/Radio commands from the Beo4 , the beosound doesnt respond at all , as it should. The beolab2000 can acces CD/radio from the beosound But the TV or Beolab cant play Net music or Net radio from the beoport
Craig
- Posts 4,855
Patrick, did the stand by light on the Beosound flash when you set the options? Craig
patrickpeeten
- Posts 11
yep , all the lights flashed once
Craig
- Posts 4,855
Very strange, by putting the BS9000 in option 0 and the Avant in option 2. Pressing CD on your Beo4 should make the CD play through Avant and any speakers connected to it. Craig P.S. Where are you located?
Craig
- Posts 4,855
patrickpeeten:im located in belgium
Had to ask, that is a bit too far to come round and have a look. Next question(s) then, was all this equipment connected and working before? What have you changed or added to the setup? Craig
patrickpeeten
- Posts 11
i once had the BS9000 right next to the Avant and both were connected by a single ML cable with all speakers on the avant , now theire is a small wall seperating them but its still the same room (on the drawing , the line showing a ML cable between the avant and the BS9000 , theire is a 4,5 to 5 foot wall about in the middle of the 2 , a 7 footer can look right over it :) ) that setup worked fine , i later expanded it. now the TV ML cable goes in a splitter box , so does the BS9000 ML cable , and that box is connected to another splitter box which has the BL2000 en Beoport on it
Craig
- Posts 4,855
Next step would be to check the connections in the splitter boxes. Just to make sure none of the wires have come loose. Craig
Page 1 of 1 (21 items)
