Latest post 09-14-2009 5:15 PM by Dillen. 7 replies.
Page 1 of 1 (8 items)
  • 12-28-2007 9:12 PM
    • leendertn
    • Not Ranked
    • Joined on 12-29-2007
    • Sacramento/USA
    • Posts 2
    • Silver Member
    Beomaster 2400 hum & Beogram 3404 DIN to RCA phono adapter to non B&O receiver
    Hello,
     Joined mere minutes ago...the downloads of the manuals alone is worth the price of membership (as others have noted).
    I have a B&O Beomaster 2400 that has performed great since the early 80's. Had it serviced once when most of the red control lights went out. That shop is no longer around here (California's SF Bay area). Just a few months ago it developed a serious hum and from what I gather on these forums is that it's likely the power supply that needs replacement. The hum is there all the time, both through the radio, phono and a CD player I have hooked up. The speakers are B&O S75's and they're fine. So, now I have purchased a Onkyo receiver to hold me over while I fix this puppy. I'd like to do it myself if at all possible. Also, while I am gathering info on just how to accomplish this, I am also in need of a DIN to RCA jack for the connection of my Beogram 3404 record player to the new receiver. I count 7 pins, I am assuming one is for the remote, while the others are non B&O specific? Just guessing. Looking forward to hearing from any of you out there. Thanks in advance.
  • 12-29-2007 3:58 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 2400 hum & Beogram 3404 DIN to RCA phono adapter to non B&O receiver
    Welcome to Beoworld !
    Grab a capacitor kit and replace the lot.
    Aging capacitors are the causes of almost 100% of the cases of humming in these little beauties and there is a lot of them in there.
    A lamp kit is also available.
    The two outer pins in the 7-pin DIN will unscrew using a tiny watchmakers screwdriver, that will make the DIN fit in any standard DIN/RCA adapter.
  • 12-29-2007 4:27 PM In reply to
    • leendertn
    • Not Ranked
    • Sacramento/USA
    • Posts 2
    • Silver Member
    Hello Martin,
     Tusind tag..Any idea where these lamp kits/capacitor kits for this model can be had? Thanks again in advance...
    Leen
  • 12-30-2007 6:37 AM In reply to
    • Dillen
    • Posts 5,008
    PM to you !
  • 04-11-2008 12:02 PM In reply to
    Hi ! Martin. May i also know where i can get the capcitors and the lamp kits for the Beomaster 2400? My baby is humming now and if i turned it on higher than easy listening volume,it just gone distorted. Thank you.
  • 04-13-2008 6:00 AM In reply to
    • Dillen
    • Posts 5,008
    PM to you !
  • 09-14-2009 3:38 PM In reply to
    • Macus
    • Not Ranked
    • Joined on 09-14-2009
    • Kungälv, Sweden
    • Posts 25
    Send a PM to me too!
    Owner of a Beomaster 2400-2 and a pair of Beovox 1001 speakers.
    My other favourite brands are Apple, Philips and Infinity.
  • 09-14-2009 5:15 PM In reply to
    • Dillen
    • Posts 5,008
    You have an answer to your PM.
