okay thats very helpful! BUT.. i have a pre-amp, and theres a gain knob, and 3 buttons one says 'MIC' one says 'AUX' and the other says 'MID', and then i have the input and output points.... a 4 pin 'IN' socket and another 4 pin 'OUT' socket.. plus red and white in and out points........ what should i have in where???? should all these points be full? or should the 4 pins be in only, or the red and white points only?
Im so confused!!
Thanks for the really quick reply last time by the way!!
Romilly Winter
