hello again Al,
Unlike your question concerning the Sci-ATL box, in this case more cables are better.
Use AV-4, you'll be glad later.
Run EVERYTHING, yes, everything. You could skip the composite (CVBS), but what's one more little cable at a party like this? ;-)
For data run a mini male-to-male cable, unless the brigand who sold you the DVD-1 included the short m-f adaptor, in which case you could run the extension cord that came with your A8 headphones...you do have those, right? Attach that to the IR port jjust like the flasher for the Sci-ATL box.
From the Beo-4, turn the set on press menu-menu, select connections, change AV-4 to DVD, press 'go', check settings, press 'go', select 'DVD-1 from the top of the list, press 'go' one last time, 'exit' and sit back and revel in the fact that you are one of the 17 people in the US with a DVD--1. Enjoy!
Russ
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
