Latest post 12-15-2007 5:08 PM by 2mojo2. 2 replies.
Page 1 of 1 (3 items)
  • 12-13-2007 7:34 PM
    • 2mojo2
    • Not Ranked
    • Joined on 12-14-2007
    • Posts 2
    Beogram RX speed problem
    My Beogram RX has been unused for several years. Installed a new cartridge today and was shocked to find that the speed was much too slow. On a crazy hunch, I set the speed to 45 rpm and tried it on a 33 record. It sounded right!
    Is this more likely a belt problem or a control problem? Advice, please.
    Filed under:
  • 12-14-2007 2:06 AM In reply to
    Re: Beogram RX speed problem
    I doubt it is the belt. The motor will be running slow. I would start by running the deck for a few hours at 45 - see if it speeds up! There are controls to alter the speed but I only have the service manual for the 1800 though I am pretty sure the RX was very similar. There should be two holes on the bottom of the deck which lead to some variable resistors that will change the speed. however I think it likely that the motor needs servicing and probably some electronic components need replacing. Where are you based? - we might be able to recommend a helpful service source.
    Welcome to Beoworld.
  • 12-15-2007 5:08 PM In reply to
    • 2mojo2
    • Not Ranked
    • Posts 2
    Thank you, Peter.
    I am in the mid-Atlantic region of the United States.
    2mojo2
