Latest post 12-06-2007 3:18 PM by Bagg518. 5 replies.
Page 1 of 1 (6 items)
  • 12-06-2007 10:47 AM
    iPod Compatability with Older System
    I have a BeoSound system from like early to mid ninties. I am not sure of the exact model number, but it looks identical to the current BeoSound 3200.
    Is there anyway I can hook up my iPod to this system? My dad gave it to me because he is upgrading, and I was hoping I wouldn't have to burn all my music onto CDs.
  • 12-06-2007 10:56 AM In reply to
    • godlund
    • Not Ranked
    • Joined on 04-27-2007
    • Sweden
    • Posts 17
    Re: iPod Compatability with Older System
    You could probably solder a 3,5mm to DIN and hook up your ipod. Or you could go advanced with; http://home.swipnet.se/ridax/ipod.htm
  • 12-06-2007 11:29 AM In reply to
    You need a din to stereo minijack cable and plug into the AUX port on the B&O
    Regards Graham
  • 12-06-2007 12:10 PM In reply to
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    The cable Graham mentioned is available on ebay all the time. There are some clever docks available too, which allow you to hook up you pod to your hifi and tv. The soft ware in the dock allows you to navigate your ipod via remote on your tv in some really nice looking graphics. check out a company called DLO http://www.dlo.com/Products/homedoc_dx_Prod.tpl
    If you use one of these docks you will need a Xover to din, which your dealer will help you with.
    Hope this helps
    Cheers Graeme
  • 12-06-2007 1:03 PM In reply to
    I'd get it from LifeStyle. Theirs are from the Danish manufacturer Bosscom. Perfect workmanship and quality and  a very nice price. Attach one end to your iPod and the other  to the AUX or TAPE ports of your unit. And you're set.
    http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=1440
  • 12-06-2007 3:18 PM In reply to
    Great, thanks for your help. I'll let you guys know which one I decide on.
