Latest post 12-06-2007 5:03 AM by cat100. 2 replies.
Page 1 of 1 (3 items)
  • 12-05-2007 6:07 PM
    • cat100
    • Not Ranked
    • Joined on 12-05-2007
    • Posts 2
    HELP! ''Not turning on from Standby' issues with my Beovision LX2500 - any advice?
    My beloved B&O tv decided to switch itself off this morning and now refuses to switch back on again. It comes off standby for about half a second, whilst making a slight buzzing noise, and the red light momentarily goes off, but then it switches itself onto standby again.
    Anyone have any idea as to what could be wrong with it?
    Also if there does appear to be a fault, it would be great if anyone can reccomend someone who could fix it at a reasonable price in the london area.
    Cheers all.
    Filed under: , ,
  • 12-06-2007 4:09 AM In reply to
    Re: ''Not turning on from Standby' issues with my Beovision LX2500 Television - any advice?
    Suggest you PM member nobby who is our resident "expert" on this age of set.
    Regards Graham
  • 12-06-2007 5:03 AM In reply to
    • cat100
    • Not Ranked
    • Posts 2
    Thank you Joey, i have PM him, fingers crossed it isn't too serious or expensive!
    I am sure it is trying to turn on for a little longer this morning before stropping and switching itself back off again, but maybe that is just my imagination....!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
