Latest post 04-24-2007 8:16 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 04-23-2007 2:12 PM
    Masterlink Beovision 3, Beosound 9000 and Beosound 4
    Hi all,
    this is my setup: the beovision 3 and the beosound 9000 are in the living room. The beosound 4 is in an linkroom configured with Audio Option 6. In the Beosound 4 is a DAB Module fitted. There is nothing else in the linkroom. The Beovision 3 has the Surround Sound Module fited. There are two Beolab 4000 connected to the Surround Sound Module. The Beovision has been configured with Video Option 2. The Beosound 9000 has been configured with Audio Option 0. There is also a Beoport connected to a Mac Mini in the living room. All devices are connected via Masterlink.
    Here is my question: Is it possible to listen to the DAB program from the Beosound 4 from the link room in the livinig room? If it is possible, can somebody tell me which options i have to use and which commands i have to commit?
    It is possible to listen to the 6 CD´s from the Beosound 9000 in the linkroom via the LINK command. It is also possible to listen to the radio program fromt he Beosound 9000 in the linkroom via the LINK command. It is not possible to listen to radio nor the CD from the linkroom on the Beosound 9000 via the LINK command. I can use N.MUSIC and N.RADIO in both the living room and linkroom.
    Thanks a lot for your help.
    Best regards
    Edgar
  • 04-23-2007 5:18 PM In reply to
    Re: Masterlink Beovision 3, Beosound 9000 and Beosound 4
    You cannot listen to the DAB radio in any other room besides the room it is in I am afraid. Only one audio master is possible with the others being slaves. The only exception is the use of the Beolink PC2/Beoport which can be operated in any room.Slave units can only play in the room they are situated in. Master units can operate in any room.
  • 04-24-2007 5:53 AM In reply to
    Hi Peter,
    thanks for your reply. Is it possible to make the Beosound 4 the Audiomaster and to demote the Beosound 9000 to a slave and still listen to sources from the Beosound 9000 through the Beolabs connected to the Beovision 3?
     Best regards
    Edgar
  • 04-24-2007 6:57 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    No!
  • 04-24-2007 8:16 AM In reply to
    dornbirn2000:
    Hi Peter,
     Best regards
    Edgar
    Interesting question! Probably not but worth investigating! I can see issues with remote control in that scenario as you would set the 9000 to option 6 and when you were operating the TV or BS4 when in the same room, you would get a conflict. What does Ignace think? can you run that one through the PCG?
