Hello,
I am owner of the DVD2 together with an Avant 32 VCR and I have a big problem with this combination:
The RECORD-key on Beo4 doesn´t work with the DVD2, because only the integrated Videorecorder of the AVANT reacts by using the RECORD-key.
Therefore it´s not possible to make records from a camcorder and to record directly from the tuner (only recordings by using the timer is possible).
I have tried to disconnect the Videorecorder in the service-menue of the AVANT (in the setup-menue by 0 0 GO), but no chance: the DVD2 doesn´t react by the RECORD-key.
My dealer contacted B&O-support who told him, that the RECORD-function is reserved for the internal Videorecorder of the AVANT.
Has anyone an idea to solve this problem?
I´ve been waiting for several years for a HD- and DVD-recorder by B&O. The DVD2-solution by Philips is very poor, so I´m very disappointed! If the DVD2 can´t be used together with an AVANT VCR it would be a shame for B&O!
Has anybody an idea to solve this problem?
Greetings from Thomas (sorry for my unperfect english!)
