Hello everyone,
I need HELP AGAIN! I've troubles to configure my beo5
It's a similar problem I had with the picture formats, about using the 4 arrows control inside a command
I cannot do work BALANCE or FADE options with my beo5 (hard keys or screen keys)
With
Beo4 I use the 4 key arrows inside the SPEAKER command to control
those options... but after several attempts I don't know how configure
the correct IR code keys in Beo5 to achieve these functions
Thanks in advance for any help.
