have'nt bought anaything electrical recently. I still have the problem.
In
fact I have two X Active Kits and I have interchanged them and still
notice the problem. So the problem doesn't seem to comme from the
connections. Now when I connect an MX4002 to the kit using the 7pin
cable and then I connect the beolab 4500 to the TV powerlink sockets,
the sound is clear as it should be. This suggests the MCL cable from
the BM7000 down to the kit has no problem.
I only get the hum
noice when I connect the speakers to the powerlink of the kit.
Now as I am writing this post, I am thinking the only common
situation is that I am using the same eclectrical block to power
the kit. I will try to change it. Strange !!
