Does anyone now what type of connection/wire B&o are using to the inbuilt DVD player??
Because if i go in to the DVD setup i can choose RGB, component or composite video...
And RGB = usually scart connection or are they using a CAT-5e cable in BTW. ??
The default setting is RGB and = The best PQ out of the the 3 settings you can make..
If you chose component the PQ are drastically getting worse!
So are they using scart (Like BV9) or CAT-5a cable?
Just curious????
Regards
