If phone numbers in the phone are copied to the SIM card, they all appear twice. Is there any way to copy numbers to the SIM card without having duplicate numbers in the phone book?
When my Serene is in the closed position, the two pieces seem a little loose at the hinge. They will move slightly sideways in relation to the other half. When open, all is tight and there is no movement. Is this normal?
Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
