Latest post 11-27-2007 6:42 AM by shane. 6 replies.
Page 1 of 1 (7 items)
  • 11-26-2007 8:17 AM
    2 Serene questions
    If phone numbers in the phone are copied to the SIM card, they all appear twice. Is there any way to copy numbers to the SIM card without having duplicate numbers in the phone book?
    When my Serene is in the closed position, the two pieces seem a little loose at the hinge. They will move slightly sideways in relation to the other half. When open, all is tight and there is no movement. Is this normal?
    Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 11-26-2007 9:08 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: 2 Serene questions
    Ours is a little loose when closed also, so i guess it is normal. When you copy the numbers it may ask to move or keep original. Select move, otherwise you'll have to go through and delete all of the numbers in the phone memory.
  • 11-26-2007 10:05 AM In reply to
    • beobeo
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Spain
    • Posts 953
    I have the same problem when the phone is closed. A bit loose. Have tried tightening the screws but still the same.
    Gustavo
  • 11-26-2007 11:08 AM In reply to
    • Ericvr6
    • Top 500 Contributor
    • The Netherlands
    • Posts 205
    beobeo:
    my first one did not had this problem my second has
    eric
  • 11-26-2007 1:44 PM In reply to
    I can not find a "move" function on mine?
  • 11-26-2007 8:10 PM In reply to
    • Dave
    • Posts 2,328
    copy all numbers to the sim card, and then put in a different sim card and select delete all.
  • 11-27-2007 6:42 AM In reply to
    • shane
    • Not Ranked
    • Joined on 04-18-2007
    • Posts 7
    is there anyway to copy numbers to the sim card all at once instead of individually.
    very time consuming ;(
