I am trying to take off the module of the surround 5.1 of a BC1.
Due to the fact that some ( the upper ) of the attaching pins are broken the module as it is top heavy keeps dropping off.
I still have the original cap with out the module which doesnt need the pins and until I have ordered a new part I want to use at least the unit for TV etc. If I can get the module off its possible to close it up with the original cap.
Problem is I am unsure how the module is connected? So before I ruin something I guess some advice is very welcome.
As I see it the best way is to disconnect the module from the BC1 itself. I see a grey sort of connector with something that seems a safe- click system. its possible to manouvre it so it unlocks ?. So my guess is that it will free the connector from its base. If I am right the module is attached to the BC1 with a slim grey connector? When pulled the connector doesnt give way though ?
Am I missing something or should I use more force? All is not in the easiest spot and the connector seems a bit fragile?
Hopefully some one can help me out here,.....
Regards EOB
