Latest post 04-22-2007 2:15 PM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 04-22-2007 7:08 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    "Locking" the arm on a Beogram 1203 for transit
    Is this possible, and if so how ?
    Cheers
    Nigel
  • 04-22-2007 8:13 AM In reply to
    Re: "Locking" the arm on a Beogram 1203 for transit
    Don't think it is. The arm will not lower but will swing. I would suggest a piece of foam rubber under the arm and some good tape.
  • 04-22-2007 2:02 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    On the part where the arm rests when not in use. Does it have a Black plastic piece. If it does it should pull out and lock the arm in place. This is how the BG1200 works.
    CraigBig Smile
  • 04-22-2007 2:07 PM In reply to
    The 1202 and 1203 differ considerably from the 1200. The 1202 (the one to have!) is really pretty similar to the Beogram 3000 and lost the arm support you are talking about. I think the 1203 was more like the Beogram 2000 and so was not quite so advanced and was cheaper to produce. I don't think it had a peg either.
  • 04-22-2007 2:15 PM In reply to
    • Craig
    • Posts 4,855
    Had a Beogram 1200 for a while, thought the 1203 was almost identical.  Obviously not.
    CraigBig Smile
