Britpop: Whatare you using for your speed test?
578.4KB/sfor me.
Hi, thanks for the tip.
Via an Ethernet connexion : Download Speed: 3397 kbps (424.6 KB/sec ) UploadSpeed: 844 (105.4 KB/sec )
- With manual parameters : DownloadSpeed: 4206 kbps(525.8 KB/sec ) Upload Speed: 843 kbps (105.4 KB/sec )
Via Airport activated : Download Speed: 3232 kbps (404 KB/sec ) UploadSpeed: 841kbps (105.1 KB/sec )
Do you think it is better to remain with an Ethernet connexion in term of stability/ performance, instead of Airport ?
Cheers,
Guy
P.S : sorry for the format of my message, it seems Safari doesn't consider the font size and family parameters...
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
