Latest post 11-15-2007 12:20 PM by deaddruid. 6 replies.
Page 1 of 1 (7 items)
  • 11-07-2007 11:22 AM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    BeoVision 2000 speaker foam rot
    Both speakers on my BeoVision 2000 have suffered foam rot, and therefore have bits missing. I suspect that refoaming such small drivers is not practical - are the originals, or something very similar still available?
    Mark
    Filed under: , ,
  • 11-07-2007 12:44 PM In reply to
    Re: BeoVision 2000 speaker foam rot
    Indeed.Part No 8480233.You'll need to order them via your local "Beosuit",and they are not cheap! Expect to pay about £20 each.There are other drivers that will physically fit,but they won't sound as good!
    Regards,
    Nick
  • 11-12-2007 4:36 AM In reply to
    • deaddruid
    • Posts 247
    Thank you, Nick. Do I take it that these drivers were made specifically for B&O, and that's why they are the only source?
    Mark
  • 11-13-2007 5:30 AM In reply to
    Yes all drivers B&O use is made specially for B&O.. Smile thy never use stock drivers..
  • 11-13-2007 9:08 AM In reply to
    • deaddruid
    • Posts 247
    OK, I guess it's time to go meet the suit...
    Thank you both.
    Mark
  • 11-13-2007 2:08 PM In reply to
    Yes indeed,they were made by ITT in Germany,but the spec is better than the standard telly speakers.You can buy a speaker unit that will fit,and in fact looks very much like the original,for about half the B&O price.I was dissapointed with the sound though!
    The original drivers together with the special sound tubes they fit into,give the telly that distinctive good sound.Great little telly's too!
    Regards,
    Nick
  • 11-15-2007 12:20 PM In reply to
    • deaddruid
    • Posts 247
    OK, beosuits it is, then. Thank you, Mark
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
