Trucker: Hallo Joc,
I too have a BV7 mrk II seven months old. And i am concidering and upgrading to mrkIII.
How much will it cost to switch to the new, and the dealer would buy the markII?
What did you have to pay for the switch over, if you delivered the mrk II to the dealer?
Well, each dealer will probably charge a different amount for
an upgrade, so I would suggest to phone about.
As there is only the one dealer in Northern Ireland that
leaves me at a bit of a disadvantage, but, you will have to take into account
that your TV is worth less than what you paid for it, and the new MKIII costs
more (because of the 1080p panel & BeoSystem3 bits). It all depends on how
much YOU are willing to pay for the upgrade, and if you NEED the 1080p, HDMI etc
For me the dealer is coming out to my house, and just
replacing the screen (speaker & stand is staying), and taking the old screen away.
Hope this helps, a bit…
