Latest post 11-06-2007 10:47 AM by PhilLondon. 7 replies.
Page 1 of 1 (8 items)
  • 11-05-2007 4:59 PM
    Just ordered
    Well after having a BV7-40 mkII for just over a month, I have decided to upgrade to the BV7-40 mkIII 1080p screen.
  • 11-05-2007 5:16 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Just ordered
    Are you going to keep the MKII aswell? Link room maybe.
    CraigSmile
  • 11-05-2007 5:31 PM In reply to
    Re: Just ordered
    nope have no need or the room to keep the mkII, so its going to the shop
  • 11-06-2007 2:41 AM In reply to
    • Trucker
    • Not Ranked
    • Joined on 04-22-2007
    • Denmark
    • Posts 33
    Re: Just ordered
    Hej,
    what did you have to pay for the switch over from mrk II to MarkII.
    Trucker
  • 11-06-2007 6:28 AM In reply to
    • JoC
    • Top 500 Contributor
    • Joined on 08-20-2007
    • Northern Ireland
    • Posts 121
    Re: Just ordered
    Ditto, my MKII is 6 months old, I decided to upgrade, and the MKIII is getting installed today. Smile
  • 11-06-2007 7:31 AM In reply to
    • Trucker
    • Not Ranked
    • Denmark
    • Posts 33
    Re: Just ordered
    Hallo Joc,
    I too have a BV7 mrk II seven months old. And i am concidering and upgrading to mrkIII.
    How much will it cost to switch to the new, and the dealer would buy the markII?
    What did you have to pay for the switch over, if you delivered the mrk II to the dealer?
  • 11-06-2007 8:41 AM In reply to
    • JoC
    • Northern Ireland
    • Posts 121
    Re: Just ordered
    Trucker:
    Hallo Joc,
    Well, each dealer will probably charge a different amount for an upgrade, so I would suggest to phone about.
    As there is only the one dealer in Northern Ireland that leaves me at a bit of a disadvantage, but, you will have to take into account that your TV is worth less than what you paid for it, and the new MKIII costs more (because of the 1080p panel & BeoSystem3 bits). It all depends on how much YOU are willing to pay for the upgrade, and if you NEED the 1080p, HDMI etc
    For me the dealer is coming out to my house, and just replacing the screen (speaker & stand is staying), and taking the old screen away.
    Hope this helps, a bit…
  • 11-06-2007 10:47 AM In reply to
    Re: Just ordered
    Just a remark... the new MKIII does not cost more than the MKII at least with my dealer.
