Latest post 11-28-2007 6:32 PM by Santiago. 37 replies.
Page 1 of 2 (38 items) 1 2 Next >
  • 11-04-2007 8:06 AM
    Picture format changing up/down arrows
    Hello everybody,
    I've found a problem inside my beo5 picture format functions:
    With beo4 when I'm under picture format 1 or 2 commands, I can change some parameters inside those by using the "UP" and "DOWN" arrows (3 different format1 sizes and up-down panning the format2 zoom).
    These arrows seem not work with my beo5... what happen with yours?
    Thanks in advance for your responses.
    Santiago
  • 11-04-2007 10:58 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Picture format changing up/down arrows
    Hi Santiago.
    On the picture screen, I have three options. They are 'Standard', 'Zoom' and 'Widescreen'.
    Standard is format 1, Zoom is format 2 and Widescreen is format 3.
    Andy T.
    Poor me, never win owt!
  • 11-04-2007 11:12 AM In reply to
    jandyt:
    Hi Santiago.
    Andy T.
    Hi Andy,
    Of course I have those same 3 options, and the 3 works fine, but I'm not talking about that.
    As usual I think I'm not able to express me correctly in English.
    I'm talking about the arrows options "up" and "down" INSIDE each format 1 and 2.
    So INSIDE the format 2 with beo4 I can "pan" the picture upside down with the "up" and "down" arrows keys and INSIDE the format 1 I can change between 12:9, 14:9 and 15:9 picture formats using the same arrows... do you know what I mean now?
     Well, the problem is that using my beo5 I'm not able to control this "arrows" feature inside picture formats.
    Santiago
  • 11-04-2007 11:34 AM In reply to
    • Jandyt
    • Posts 13,004
    My fault mate, not yoursEmbarrassed
    There was nothing wrong with your english, I just didn't read your post properly.
    I see what you mean, I have the same problem. Guess you will need to either program the hard buttons or better still, add two new soft buttons in the picture screen. You could make some really pretty arrows.
    Andy T.
  • 11-04-2007 11:48 AM In reply to
    jandyt:
    Andy T.
    Ok thanks, because now I see I'm not alone...
    I've already try re-configure the 2 beo5 hard keys and also make 2 new screen buttons... exactly as you suggested Andy ! but with no success in both cases, I've not yet found the good IR code combination to do it work Confused so irritating Angry
    Santiago
  • 11-04-2007 6:46 PM In reply to
    There is a button on screen called variation that change the sub formats.
  • 11-04-2007 7:09 PM In reply to
    The Stig - ver. 1.5:
    Sorry but I cannot find anything called "variation",
    Could you explain it with more detail please? thank you.
    Santiago
  • 11-05-2007 2:29 PM In reply to
    • Jandyt
    • Posts 13,004
    Me neither!
    I have spent about two hours trying to sor this one. If anybody get's there before me, let me know.Confused
    Andy T.
  • 11-05-2007 3:00 PM In reply to
    What tv is the remote set to control? mine is BV7 and there it's present
  • 11-05-2007 3:04 PM In reply to
    Hello Andy,
    I see we are both in the same boat now Big Smile
    Best regards.
    Santiago
  • 11-05-2007 3:05 PM In reply to
    The code looks like this:
    0:000:TV:PICTURE_FORMAT+0:000:TV:WIND
  • 11-05-2007 3:10 PM In reply to
    So do you can use the beo5 to change the picture sub-formats in the BV7? (14:9 <-> 15:9 <-> 4:3)
    In my avant I cannot get it work using the beo5.
    Santiago
  • 11-05-2007 3:16 PM In reply to
    • Jandyt
    • Posts 13,004
    Thanks Stig.
    I too am using an Avant. I will try your code tomorrow and report back.
    Andy T.
  • 11-05-2007 3:17 PM In reply to
    This macro doesn't work for me.
    Neither "step_up" or "cursor_up".
    I have a computer IR receiver that can detect and show me all the IR codes sent for the beo remotes,
    and the most strange thing in this case is that both beo4 and beo5 are sending the same codes (14 + 201C) Surprise
    but with the beo5 the avant reaction is "next and previous tv channel" and with beo4 is "change the picture format 1 from 15:9 to 14:9" Hmm
    Santiago
  • 11-05-2007 3:29 PM In reply to
    Ok this is the code it sends to my BV7
  • 11-16-2007 7:30 AM In reply to
    Hello everybody, I need help again!
    I'm trying to find the Beo5 IR codes equivalent to the beo4 command "A-V.AUX".
    I want shut off the avant screen while listening music through the V.AUX input.
    I've already tried this: including "V.AUX" inside the "AV" screen and also the "Picture_toggle" beo5 IR command, but with no success Sad
    Any ideas?
    Thanks in advance.
    Santiago
  • 11-16-2007 9:01 AM In reply to
    You will not find a code in the tool for A-V.AUX however you will have on your screen V.AUX and AV.. and if you press V.AUX followed by AV.. it will effectively give the A-V.AUX. I have checked the codes transmitted from the Beo5 and they are the same.
    You cannot macro it into one button click because you cannot add "AV.." and in fact any command like AV.. which gets automatically added by the tool and is followed by ".." cannot be moved to another screen without lossing its functionality..
    Regards Keith....
  • 11-16-2007 12:24 PM In reply to
    Keith Saunders:
    I've tried this first sequence with beo5: press V.AUX followed by AV.. and the avant screen doesn't switch off
    I've tried this second sequence with beo5: press AV.. followed by V.AUX and the avant screen doesn't switch off
    But if I use  "A-V.AUX" with my beo4 the avant screen switch off perfectly well.
    The question now is: there is a way to switch off the avant screen while listening a video source, by using the beo5?
    Thanks.
    Santiago
  • 11-17-2007 2:33 AM In reply to
    I think we have here another one of these "timing" issues.
    I saw a similar problem helping another member with the "back" button on a DVD.
    I had checked the output from the Beo5 in terms of binary string sent and they appear to be the same, so this is another one to investigate further..
    Regards Keith....
  • 11-17-2007 4:53 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Create a button that sends V.AUX in audiomode : 0:000:RADIO:AUX_V
    Should work. I hope this helps.....
    Regards Stefan
  • 11-17-2007 6:50 AM In reply to
    stefan:
    Regards Stefan
    Stefan, IT WORKS!!!! Party!!!
    You've found the key Yes -  thumbs up
    I've added 4 different video "turn off screen" keys for 4 different video sources, so 16 new buttons which all of them works perfectly well now.
    Thank you very much for your help, Stefan.
    Santiago
  • 11-17-2007 8:58 AM In reply to
    Very good Stefan, we were clearly trying to find the complex answer when there was a simple solution. Its always the way..
    Regards Keith....
  • 11-17-2007 2:38 PM In reply to
    • Jandyt
    • Posts 13,004
    Nice one Stefan!
    It seems AV just sends a video based signal to Audio and vise versa.
    Therfore, If I need AV in my Radio screen and my Sat screen, I can't copy it. I'll have to make to different AV 'buttons'.
    Glad you're sorted Santiago.Smile
    Andy T.
  • 11-18-2007 9:00 AM In reply to
    • stefan
    • Posts 1,733
    Thanks for the kind words! Yes, Andy, sure, you`re right. This works also vice versa. If you want to listen to the radio while watching TV it`s: 0:000:TV:RADIO. But I`m afraid this not the answer to the picture-format question. When I look at all the picture-buttons (p.mute, variation, optimise, arro down/up, standard, widescreen....) they all show me "2" - just the number 2 (!??!). It sounds a bit cryptic (right word?) but they all work. Maybe this is a more complex question that needs a more complex answer, what do you think, Keith? I would be highly interested in a solution. But meanwhile maybe this helps: Santiago, tell the configuration tool you have a BV 7. This will create a "Picture"-button including submenu with all the buttons mentionened before. Copy this button into your configuration and hopefully it works like you want it - good luck. Stefan
  • 11-18-2007 12:38 PM In reply to
    stefan:
    Stefan, you're a GENIUS !!
    It WORKS!!!! Party!!!
    Andyyyy !!!!!! do it, and the picture format problem will be definitely solved.
    The BV7 MKI picture format screen has 5 more buttons than the avant one...and it has two "on-screen arrows" which does the work I was searching.
    Now all this post can be labelled as "SOLVED" Smile
    Once again Stefan: THANK YOU VERY MUCH for your precious help Yes -  thumbs up
    Santiago
