Latest post 11-08-2007 4:39 PM by Sundby. 5 replies.
Page 1 of 1 (6 items)
  • 11-03-2007 8:20 PM
    • Klas
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Singapore
    • Posts 96
    European BS3 and US BV4 - do they work together?
    Besides the different power voltage - which can be fixed with a voltage transformator....would the NTSC / PAL make a conflict?
    Can you controll the outsignal from the BS3 to be either NTSC or PAL? Or vice versa- can you control the BV4?
    And the last and final question....what panel sits in a BV 4 type#: 8951 / item: 1895126? How old is this panel and would it work well with the BS3?
    As you probably figured out i'm thinking of buying a new BS3 to replace my existing BS1 and then buy a 2nd hand BV4 which in this case is from the states.....
    BTW - why are new BV9 so much cheaper in the US than in Europe? about 30>40% cheaper......anyway to reconfigure a US version to European (voltage and the digital tuner?)
    All the best
    Klas
    Grant me the serenity to accept the B&O I can't afford
  • 11-03-2007 8:42 PM In reply to
    Re: European BS3 and US BV4 - do they work together?
    I believe the european BV9 has a HDDR included while the US ha snot. Also, european prices include 15 to 20% sales tax. The US price is without taxes. Lastly, the $ is in free fall compared to 6 month ago.
    JK
  • 11-03-2007 8:44 PM In reply to
    And one more word of warning. If you think about shipping a plasma from US to australia, if you do not transport them upright standing they will get damaged.
    JK
  • 11-06-2007 11:13 AM In reply to
    • Klas
    • Singapore
    • Posts 96
    any thoughts on the NTSC/PAL issue between plasma and BS3?
  • 11-06-2007 3:55 PM In reply to
    Just a *bump.. I'm really interessted in the question as well..
    Thinking of buying a BS3 in the US to work with EU BV7-40 MkII.....
    Somebody out there must know
  • 11-08-2007 4:39 PM In reply to
    Anyone??
