Besides the different power voltage - which can be fixed with a voltage transformator....would the NTSC / PAL make a conflict?
Can you controll the outsignal from the BS3 to be either NTSC or PAL? Or vice versa- can you control the BV4?
And the last and final question....what panel sits in a BV 4 type#: 8951 / item: 1895126? How old is this panel and would it work well with the BS3?
As you probably figured out i'm thinking of buying a new BS3 to replace my existing BS1 and then buy a 2nd hand BV4 which in this case is from the states.....
BTW - why are new BV9 so much cheaper in the US than in Europe? about 30>40% cheaper......anyway to reconfigure a US version to European (voltage and the digital tuner?)
All the best
Klas
Grant me the serenity to accept the B&O I can't afford
