Latest post 11-02-2007 3:22 PM by The Stig - ver. 1.7. 7 replies.
Page 1 of 1 (8 items)
  • 11-02-2007 7:50 AM
    DVI-D and DVI-I
    anybody can confirm the type of DVI connections for the following:
    - Beocenter 6-23. Is it DVI-I?
    - Beosystem 3. Is it DVI-D?
    - Beovision 4-50 or Beovision 4-65: Is it DVI-D?
    - Beovision 7-40. Is it DVI-D?
    S. Fray
  • 11-02-2007 8:51 AM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Re: DVI-D and DVI-I
    Its DVI-1
    DVI dual works as well- it just has more pins that dont do anything!
    For the record I experimented with some very expensive cables and they did not do much to improve an already great picture- has to be said the B&O ones looke rather poor quality for the prices they were asking.
    For the record the best quality cables that many home cinema installers use is lindy.com  I have connected mine with a lindy 5 mtr dvi dual( some manufactuers dont do dvi1)
  • 11-02-2007 10:01 AM In reply to
    Re: DVI-D and DVI-I
    Sebastien,
    I believe the following is the information you are looking for:-
    Beocenter 6-23. Is it DVI-I?       DVI-I connector/audio L-R in
    Beosystem 3. Is it DVI-D?        2 x DVI-D Female
    Beovision 4-50 Is it DVI-D?        1 x DVI-D Female (24 pin)
    Beovision 4-65: Is it DVI-D?       2 x DVI-D Female
    Beovision 7-40. Is it DVI-D?       1 x DVI-D Female
    Regards Keith....
  • 11-02-2007 10:19 AM In reply to
    Re: DVI-D and DVI-I
    Thanks Keith.
    It's just to see if I am using the right DVI cables. I guess I am using DVI-D cables even with my Beocenter 6-23 and the image is OK.
    S. Fray
  • 11-02-2007 12:22 PM In reply to
    • JoC
    • Top 500 Contributor
    • Joined on 08-20-2007
    • Northern Ireland
    • Posts 121
    Re: DVI-D and DVI-I
    Keith Saunders:
    For the MKII it is DVI-I, and this is an input only.
    For the MKIII it is DVI-D, and this is an output only.
  • 11-02-2007 2:57 PM In reply to
    Re: DVI-D and DVI-I
    Sorry but DVI-D is not dual it's digital only, and DVI-I is analog and digital.
    BV6-22 is the only TV with DVI-D
    BV/BC6-23/26 and BV7 has DVI-I
    BV7-40 mkIII has HDMI instead (And DVI-D output like JoC says)
  • 11-02-2007 3:05 PM In reply to
    • 355f
    • Posts 655
    Re: DVI-D and DVI-I
    The Stig - ver. 1.4:
    In relation to BS3 and BV4 dvi-d or dvi-1 works it doesnt matter which cable one uses the plugs simply have less pins! Unless my experience is unique!
  • 11-02-2007 3:22 PM In reply to
    Re: DVI-D and DVI-I
    355f:
    Maybe the plug is DVI-I, BUT the output signal is only DVI-D (Digital) both cables transfers digital DVI
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
