Latest post 10-30-2007 3:26 PM by cozza. 6 replies.
Page 1 of 1 (7 items)
  • 10-30-2007 4:44 AM
    Beosystem AV 9000 Problem - at least I could get the model correct - sorry!
    I try again. When I try to start up the Beosystem AV 9000, I get the following error message:
    SW.1.10 error 1
    on the lower display panel next to the video.
    Can anyone please help?
    anodyne1
  • 10-30-2007 7:49 AM In reply to
    Re: Beosystem AV 9000 Problem - at least I could get the model correct - sorry!
    Has this worked previously?  Or is this the first time you set it up?
    Neil
  • 10-30-2007 8:42 AM In reply to
    Bonjour Anodyne1,
    I've read you are located in Geneva, same as me Yes -  thumbs up
    I suppose you have already asked here: Choisy Radio-TV
    They have a very good technical repair service which include all vintage B&O, TVs and HIFI, and they are not very expensive.
    Good luck.
    Salutations.
    Santiago
  • 10-30-2007 10:02 AM In reply to
    Merci Blackbeard. Very helpful.
  • 10-30-2007 10:07 AM In reply to
    Hi Neil,
    Set has been working fine for the 3 years I have had it. Only thing I have noticed is that sometimes the sliding curtain on startup and stopping was occasionally a bit slower, but it always worked. Only thing I can think of is that if something is not actually faulty I may have wired it up incorrectly after a recent move.
    Best regards,
    anodyne1.
  • 10-30-2007 12:44 PM In reply to
    • root
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    your tv is not broken, i had the same problem with my AV9000
    the masterlink cable is in the wrong socket...
    Marcel
  • 10-30-2007 3:26 PM In reply to
    • cozza
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    error 1 indicates a communication problem betweeen the monitor and the base unit - probably the short masterlink cable....
