Hi all,
I am setting up a beocenter 2 with a beo4. When I push down any key from the remote controler, there is no reaction in the beocenter. Is there any action to do to initialize the communication between the beocenter and the beo4?
Thank for your help.
Joel
Suspect wrong option settings in Beocenter 2
On Beo4, press standby and list together
then list until Beo4 reads Option? Press Go
then list until Beo4 reads AOpt
then 1
Standby on Beocenter 2 should blink and Beo4 should now work.
Good luck!
Regards Graham
Hello Peter and Graham,
I tried what you just suggested me and now it works. Thank you very much for your help. This was my first post on this forum. Thank you...
Joël
