Latest post 10-30-2007 5:41 AM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 10-29-2007 5:40 AM
    • djod
    • Not Ranked
    • Joined on 10-29-2007
    • Posts 2
    Beocenter2 and beo4
    Hi all,
    I am setting up a beocenter 2 with a beo4. When I push down any key from the remote controler, there is no reaction in the beocenter. Is there any action to do to initialize the communication between the beocenter and the beo4?
    Thank for your help.
    Joel
  • 10-29-2007 5:55 AM In reply to
    Re: Beocenter2 and beo4
    Suspect wrong option settings in Beocenter 2
    On Beo4, press standby and list together
    then list until Beo4 reads Option? Press Go
    then list until Beo4 reads AOpt
    then 1
    Standby on Beocenter 2 should blink and Beo4 should now work.
    Good luck!
    Regards Graham
  • 10-29-2007 5:56 AM In reply to
    It will be set to Option 0 . You need to set it to option 1 or 2 depending on your set up. Not at home but I think it is List and red button together, use the List button to scroll to Option? and then choose Audio and then 1. Much easier with a Beolink 1000!! Sound 1 store!
  • 10-30-2007 5:10 AM In reply to
    • djod
    • Not Ranked
    • Posts 2
    Hello Peter and Graham,
     I tried what you just suggested me and now it works. Thank you very much for your help. This was my first post on this forum. Thank you...
    Joël
  • 10-30-2007 5:41 AM In reply to
    Hi Joel, Glad we could help and welcome to BeoWorld.
    Regards Graham
