Have anyone done the upgrade from HDR1 to HDR2?
Whats the difference, except HDD size?
Can you do it yourself, if you have the electronic know-how?
I want do keep my 4-Drawer Cabinet - Is the upgraded HDR1 a right way to go?
/Hebo
BV10
Thanx Coolskin!
Keep me posted.
Is there anyone else who will tell me your experince of the HDR1 or HDR2?
I have used HDR1 for two years, and it's VERY easy to use.
What's the actual difference Stig ?
Yes you press stop only. I believe it's very usefull.
Somebody told me that the DVD2 can't make timing records via the text tv !!! That's the main feature of the HDR1.. Works exactly like my old Avant...
The Dane !
