1st March February 2012
Latest post 03-11-2008 7:08 PM by kimhav. 20 replies.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: BeoPort 4.65 now availiable to download
What's new? Vista compatible? p.
PhilLondon
- London
- Posts 2,545
Well, from what I read in the spanish forum it seem to have Album pictures. p.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Just tried to install this onmy PC with no luck at all. Getting an issue with the drivers been installed. had to go back to V4.61. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
Just a small tip to those having a large music library, remember that now all titles have a CD cover, therefore the "thumnails cache settings" under the NMUSIC menu in your setup has to be matching the number of tracks you have in your "My Music" folder, otherwise BeoPlayer/BeoPort will bug because it lacks space to update the artwork database. The basic setting is 5,000 music covers, I had to set it to 8,000 to make it work OK. Also another tip to those who would like to have as many NRADIO stations in BeoPlayer as in BeoPort: if you have a friend that has a BeoPort box, install it on your PC with the BeoPort 4.65 software, then re-start your PC & unplug the whole BeoPort box, and BeoPort will shift to a normal BeoPlayer config..but with 3,000+ radio stations! I found this out as I recently sold my BeoPort box, but managed to keep all radio stations stored.
Reunion Island is greeting you!
saf
- Joined on 04-17-2007
- Posts 458
Works quite great for me with the covers etc. - not having Beomedia1, now I wish even more to be able to use Santiago's solution with S-video connection between my PC and the TV downstairs. Unfortunately, it's quite a few meters between the devices .... The new version seems to have (slightly) improved how the video drivers for my TV card cooperate with Beoplayer - this could however be very subjective ... these drivers (updates) can make you mad sometimes ... as Graigh indicates?
nlb
- Posts 60
All and Chrisreunion, did the album covers take a while to appear, and what did you get before the covers appeared? At the moment I just get the round circle (CD symbol), but I am going to increase the thumbnail cache to see if that does the trick. nlb.
saf
- Posts 458
In N.MUSIC: I had to pick an album eg and then use right button on the mouse to unfold a menu ("update cover", "update cover and info" etc.) then after going for one of the options things began to happen, ie covers start to appear etc. I have some obscure music so some of the covers were not to be found, but that's a different story I guess. Strangely, the Beoplayer doesn't seem to find any cover for "Bang & Olufsen Product Themes" (003 Tracks) ... also, you don't seem to get always exactly the cover as on the CD you just copied - but that I can understand, as they can be many versions.
GSHaigh
- North West UK
- Posts 163
I am having install issues. Runs through until USB driver installation and then just hangs. I have un-installed the old version, rebooted and still have the same problem. Any ideas? Greg
GSHaigh
- North West UK
- Posts 163
Answer..... delete the BeoPort folder under Program Files\Bang & Olufsen too!
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I just installed Beoport 4.65 and installation worked fine and net music and album covers work perfectly. However, net radio does not and it says can not connect with server. I have shut the firewall down and rebooted and still no luck. Any suggestions?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Mr10Percent
- In Transit
- Posts 441
....more importantly and "at last", it does seem to play the album tracks in order as opposed to alphabetical order.
Progress.
10%
nlb
- Posts 60
now that is good progress.
Joe
- Joined on 10-03-2007
- SoCal
- Posts 74
The Vista compatible version should be here in the first quarter of '08, thats what B&O says anyway.BeoPlayer is a pretty cool program, I am surprised that more people dont have it since its free. Joe
Its not just a product, its a way of life...
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
Chrisreunion: Just a small tip to those having a large music library, remember that now all titles have a CD cover, therefore the "thumnails cache settings" under the NMUSIC menu in your setup has to be matching the number of tracks you have in your "My Music" folder, otherwise BeoPlayer/BeoPort will bug because it lacks space to update the artwork database. The basic setting is 5,000 music covers, I had to set it to 8,000 to make it work OK. Also another tip to those who would like to have as many NRADIO stations in BeoPlayer as in BeoPort: if you have a friend that has a BeoPort box, install it on your PC with the BeoPort 4.65 software, then re-start your PC & unplug the whole BeoPort box, and BeoPort will shift to a normal BeoPlayer config..but with 3,000+ radio stations! I found this out as I recently sold my BeoPort box, but managed to keep all radio stations stored.
Picked up a new CD today, but BeoPlayer couldn't find it after I uploaded it (using BeoPlayer).. until I discovered that you can now have a maximum of 10.000 songs on your disks. Had to delete some stuff to get access to the new CD (it was there, BeoPlayer just didn't show it until I was below 10.000 tracks). In the setup menu you can increase the basic setting from 5.000 to a maximum of 10.000. It adds a cover to each song. Roger
g_veare
- Posts 5
Evening. One thing I have noticed, but I don't think anyone has picked up on yet, in BeoPlayer 4.65 is that now you can set the recording quaility to 256K and lossless. About time too. Also in the guide there are mentions of copying music to the forthcoming BeoSound 6 and Serenata. Regards, Greg
SWISS_2
- Neuchatel, Suisse
- Posts 552
Reading your post on the new Beoport 4.65 Version, I simply went to the B&O page and downloaded the upgrade. It took over from there, removing and installing everything. I did adjust the CD volume Nr up to 10,000 as mentioned. Total time with the download, and reboot was 3.7 minutes. My only problem was entering my user name & password as I had touched the cap button. The CD album info page beings the Album cover up large, which looks very good on a large plasma screen. Ready to reconnect the TV Haupage connection and see if it finally works. Thanks all for letting us know about the upgrade !
nlb
- Posts 60
It does make me wonder how B&O communicate with customers regarding software updates, without Beoworld we would be in the dark! Could B&O make a note in the newsletter... Dealers can't be bothered!
kimhav
- Joined on 09-03-2007
- Sweden
- Posts 127
Hrm.. is it just me that finds the new version of sluggish to use when switching between the different playing modes; ie Album, Playlists, etc? The GUI on my system (using the same board as beomedia box) hangs for around 1-2 minutes when switching play mode. Okey my music library current has around 25.000 tracks; but the old version 4.61 didn't have this issue and it can only be the new cover thumbnails feature makes sure that this happens.
Page 1 of 1 (21 items)
