Latest post 11-04-2007 2:33 PM by Craig. 17 replies.
Page 1 of 1 (18 items)
  • 10-23-2007 1:29 PM
    Beosystem 5000
    for 255 EUR. Is this a good buy?I won it on a auction!!
    Someone knows if Beolink 7000 works with this?
    http://www.lauritz.com/Item/Item.aspx?LanguageId=2&ItemId=1109517
    Smile
  • 10-23-2007 1:44 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beosystem 5000
    Seems like a very good buy to me. Well I would be very happy if I had paid that price anyway. In answer to your second question I think it will only work with the MCP 5000 and Terminal 5000 remotes.
    CraigSmile
  • 10-23-2007 2:35 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: Beosystem 5000
    Craig's answer is correct.  The MCP5000 and Terminal 5000 are the only remotes that operate the Beosystem 5000.
    You also need the MCL82 if you wish to extend the system to more rooms, rather than the MCL2.
    Brian
  • 10-23-2007 2:48 PM In reply to
    Re: Beosystem 5000
    ok thanx
    it will be placed in my Dressing/computerroom where I have MX4000 wich is linked to rest of the house
    I thought I could use my BL 7000 Sad
  • 10-23-2007 3:11 PM In reply to
    Re: Beosystem 5000
    Craig:
    CraigSmile
    Hmm strange, does it use it´s own ircodes???
    It´s 2-way so is BL5000/7000 to!!!??
  • 10-23-2007 3:55 PM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    Re: Beosystem 5000
    Yes, it has its own codes (it's not bl1000 compatible) and I think it also uses a different wavelength than the later products (but I'm not sure of that one). Nice find though, the collector in me likes that it has the original radial beogram instead of the later tangential one (assuming the auction description is correct) - I'd like to find a 500 system just like that one :).
  • 10-23-2007 4:09 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beosystem 5000
    If you can get one. There was a unit which allowed you to control a Beosystem 5000 with a BL1000. These are however very rare, I have only ever seen one on Ebay in the last 4 Years or so. Peter has one, not sure if it works two way though.
    CraigSmile
  • 10-23-2007 4:17 PM In reply to
    Re: Beosystem 5000
    Craig:
    CraigSmile
    ...but if you can use Bl1000..... beo4/5000/7000/5 will also work?
  • 10-23-2007 4:29 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beosystem 5000
    ....mr anders(son):
    Yes, Beo4/5/5000 & 7000 will all work. What I don't know is if they will work in two-way or one-way only. From what I have seen of the unit it uses the MCL connections to control the Beomaster.
    CraigSmile
  • 10-23-2007 4:41 PM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Re: Beosystem 5000
    Craig:
    ....mr anders(son):
    CraigSmile
    Yes, that's correct - you connect the ir converter to the mcl connections when used with a bs5000 or a bc7700/7007. When used with a bm6000/8000, an ir blaster is used. I guess it's only one-way. I actually bid on an auction for an IR converter a couple of weeks ago. The seller obviously thought it was a normal link kit (mcl2a), so it went quite cheap. Unfortunately I forgot to place a bid. GRRR!
  • 10-23-2007 5:04 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beosystem 5000
    Craig, the one Peter bought to Manchester for us to 'guess' was for controlling the BM8000 I think. Don't know if it's the same as the 5000 codes.
    Andy T.
    Poor me, never win owt!
  • 10-23-2007 5:07 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beosystem 5000
    Thats the one Andy, I think it works on most systems that had a non BL1000 remote.
    CraigSmile
  • 10-23-2007 6:39 PM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Re: Beosystem 5000
    jandyt:
    Andy T.
    It's the same converter, you configure it (choosing between bs5000/bc7700/bm8000/bm6000) by adjusting some jumpers inside the unit.
  • 10-24-2007 4:28 AM In reply to
    • Jandyt
    • Posts 13,004
    Re: Beosystem 5000
    Ah, I see.
    Thanks for that, Henrik.
    Andy T.
  • 10-24-2007 8:43 AM In reply to
    Re: Beosystem 5000
    ....mr anders(son):
    Smile
    Mr Andesson, when buying on Lauritz, don't forget the 20% commission. 2400+20% Commission=2880 SEK ≈ 312 €
    Still a good deal i think!
    Regards Ola
  • 10-25-2007 12:21 PM In reply to
    Re: Beosystem 5000
    Now in my house
    Exeptional piece of artYes -  thumbs upBig Smile
    BUT little disappointed that I can not use Beo4/7000/5 No - thumbs down
  • 11-04-2007 8:59 AM In reply to
    Re: Beosystem 5000
    Is there someone who can supply me with the manuals for this system?
  • 11-04-2007 2:33 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beosystem 5000
    If you PM me with your e-mail address, I can send you the manuals for the BM5000 and CD50. Sorry I don't have any of the others you need.
    CraigSmile
