Latest post 10-21-2007 12:47 PM by DoubleU. 3 replies.
Page 1 of 1 (4 items)
  • 10-21-2007 8:16 AM
    • Klas
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Singapore
    • Posts 96
    Humming/buzzing sound from BL3's
    Just replaced my BL 4000's with a BL3's for my homecomputer- however when connecting there is a "humming" coming out of the tweeter - this wasn't the case for my BL 4000's
     I'm using the old cable as i didn't want to reroute the cable - could it be that i need to get newer versions of the cables that are shielded? Think i read something about this prior but wanted to check first if anyone else have had the same problem
    Thx
    Klas
    Grant me the serenity to accept the B&O I can't afford
  • 10-21-2007 8:18 AM In reply to
    • jonnyb
    • Joined on 04-06-2007
    • London, UK
    • Posts 123
    Re: Humming/buzzing sound from BL3's
    Yep, you need Powerlink Mk III cables and the buzz will disappear
  • 10-21-2007 10:35 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    jonnyb:
    Correct of course, and if anyone would like to read the FAQ - here it is!!
    Lee
  • 10-21-2007 12:47 PM In reply to
    If re-routing the cable is hard to do, and if your speakers are not daisy-chained, you have the possibility, to change the plugs.
    For you right speaker, the brown wire (left signal) is not used, and you can use this wire for the ice-power. Same story for your left speaker, but this is the green wire (right signal).
