If re-routing the cable is hard to do, and if your speakers are not daisy-chained, you have the possibility, to change the plugs.
For you right speaker, the brown wire (left signal) is not used, and you can use this wire for the ice-power. Same story for your left speaker, but this is the green wire (right signal).
