What i don't understand is that if the MX7000 doesn't work with DVD2,
why B&O lists this combination in the Config Guide.
Could it be that the DVD2 only works with the MX7000IT and MX7000 Beo4 ?
(and not with the first MX7000 2-way-version)
Beovision MX 7000 IT
DVD 2
If the BeoVision it is type 78xx, it must be equipped with SW 3.13 or higher.
Order No. 8343694
If, however, it is type 87xx, the BeoVision must be equipped with SW 4.5 or higher.
Order No. 8343636
Beovision MX 7000 Beo4
DVD 2
BeoVision must be equipped with SW 2.12 or higher. Order No. 8343703
