Latest post 10-19-2007 10:35 AM by Keith Saunders. 7 replies.
Page 1 of 1 (8 items)
  • 10-17-2007 4:28 PM
    Beo 5 + non B&O equipment
    did anybody manage to get the Beo 5 to work with non B&O equipment?
    Thanks,
    S.F
  • 10-17-2007 4:48 PM In reply to
    Re: Beo 5 + non B&O equipment
    It rather depends on what you mean by non B&O. It works with Lutron equipment but that uses B&O codes. The Beo5 is not yet able to operate other equipment as the software is not enabled. Yet!
  • 10-17-2007 5:01 PM In reply to
    Thanks Peter. I mean by non B&O the products which are not manufatured by B&O i.e. HD DVD player from Toshiba for instance.
  • 10-17-2007 6:33 PM In reply to
    You need a b&o DVD controller for that or a oneremote scartcable. beo5 will never be able to control that directly
  • 10-18-2007 2:22 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Never say never, StigWink
    Poor me, never win owt!
  • 10-19-2007 8:36 AM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Sebastien:
    Thanks,
    S.F
  • 10-19-2007 8:45 AM In reply to
    In the French forum, someone said the dealer said the Beo5 can already be sent back to the factory to activate 3rd party product.
    To take with a pinch of salt.
    p.
  • 10-19-2007 10:35 AM In reply to
    The statement made in the french forum is basicly correct, but it all depends on how long you are prepared to wait for the result.
    Apparently, there is a procedure for formally requesting additions much in the same way as the procedure for adding STB's to the PUC list
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
